swappin pedals
Hello all. Here's one for ya, when removing the clutch pedal for a automatic setup, has anyone shuffled the master cylinders to the left to create more room for the brake pedal instead of having it up against the go fast pedal? I've given this thought and have looked at the setup and it looks doable. any thoughts on this?
Kevin
Are you using the Wilwood pedals? If so, it should be simple to do what you're asking from a M/C perspective. The challenge may be the balance bar configuration.
Papa
yep using the factory Wilwood pedals, removed the clutch and bolted in place, seems as though you can use either master cylinder for front or rear. the mounting seems to be symmetrical, but has it been done by someone.
On mine, the M/C bores are different front and rear, but they can be moved to the proper relative positions so that the balance bar works with the proper M/Cs.
Papa
Gotcha, I’ll make sure I’ve got ‘em right and go from there.
Thanks a lot
Kevin
