Results 1 to 5 of 5
Thread: Horizontal distance between front quick jack mount points?
    facultyofmusic's Avatar
    Feb 2021
    Sunnyvale, CA
    What should the distance between left and right front quickjack mounting holes be?
    (Apologies if there's a million posts on this already. My search for "quickjack front distance" didn't return anything useful.)
    Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
    30” center of slot to center of slot. The forward tubes often need to be bent one way or the other to get the body centered left to right.
  3. Likes facultyofmusic liked this post
    Feb 2021
    Sunnyvale, CA
    Thank you Jeff!
    Dublin, OH
    as jeff mentioned, those "outriggers" may need to be moved. get your body on and centered (measure from shock tower to the wheel well lip...the hood opening is not symmetric so don't use that as a reference) and you might need to bend those QJ mount plates. Use a longer 2x4 and a sledge to persuade the 3/4" tubing in or out. I think my DS needed to be moved over about 1/2" towards the center of the car.
    Senior Member Scott L's Avatar
    Peoples Republic of Massachusetts
    I had to move mine about 3/8 to the right. Used a ratchet strap to move the left measured from a fixed point. Hit the right with a mallet to reset the gap. my body is perfectly centered over my front tires.
    FFR 5385 MKIII. 302, 3-Link. All legal in MA 1/7/2012.
