Thanks Thanks:  8
Likes Likes:  53
Page 3 of 3 FirstFirst 123
Results 81 to 95 of 95
Thread: FFR Pre-Runner Truck Build *** SEMA 2023 Mission Complete ***
    Huntsville, Al
    The official numbers are in - it's kinda been crazy since SEMA but was able to locate a Hub Dyno close to me - must have been a sign I guess....
    I will post more later but the quick numbers are
    658RWHP on 93 @ 10psi
    1028RWHP on E85 @ 18.5psi
    very happy with the end result and met the design goal. The truck also drives soooo nice.
  2. Likes egchewy79, Geoff H, MSumners liked this post
  3. #82
    Member kabacj's Avatar
    WOW Erik!!! those are some very stout numbers!!!
    Your daily driver is actually drag truck!
    you will be able to tow your coupe to the strip on the 93 octane tune, do a few passes on the drag strip with the coupe. Fill the truck with E85, switch the tune and probably put down a better pass with the tow truck!! 4WD launches are your friend.
    Well done!
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
  4. Likes Alan_C liked this post
  5. #83
    San Diego
    Nice that the numbers are at relatively low RPMs also. Looks like more power than you probably need after about 5000 RPM, even with pump gas.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  6. #84
    Huntsville, Al
    yes- I agree - but that was the goal
    Anyway - here it is the Data.... The DBR Performance folks were really good - they gave me all the data I wanted and even gave me a folder with all the charts printed out... Drove the truck home yesterday - and WOW - street only tune vs Dyno Tune + Street Tune after = WOW WOW WOW.... the power is obviously incredible, but the drivability is super - both start up, cold manners, low speed and highway cruise.... it really makes the overall XTF experience perfect... Looking out the front windshield you honestly wouldn't realize that you have a full race truck around you.... the only really noticeable thing is how smooth and in the road the truck is... drives more like a performance car but with the benefits of a long wheel base and long travel suspension. It's really hard to put into words - but this isn't a F150 ride at all.....period!!!
    Keep in mind my truck has all emissions items still in place; IMRC's still active; Aftermarket Cats - I also have electronic open dumps; we did a back to back comparison between running through the CATS and open dump - no difference (GESI cats are king). The cams run out up top as you would expect for a truck cam - but this is the house support vehicle and tow vehicle for me.
    93 octane log: 10 PSI
    E85 log: 18.5 PSI
    Dyno Sheet:
  7. Likes Geoff H liked this post
  8. #85
    Senior Member DW66's Avatar
    Jan 2020
    Plymouth Mass
    Eric,
    Can we assume this will be in the parking lot at LCS?
    MK4 Complete kit FFR9939. Gen 1 Coyote, Tremec 3650, IRS 3.31 ratio, Breeze radiator stuff, Breeze cubby and battery mount, North Race Cars heat and A/C, RT drop trunk kit, Replica Parts radiator aluminum and brake booster spacer, FFR soft top.
  9. #86
    Huntsville, Al
    yes - I plan on pulling the Daytona with it - also plan on Texas this year as well if all goes well..... starting another build soon.
  10. #87
    Huntsville, Al
    Well we continue to hit milestones - part of my build plan was that I am replacing my home support vehicle with the XTF.... part of that is that having a lockable bed. The XTF bed is basically the same dimensions as the stock truck... the main difference is that the bed side are flat in the XTF so there is no place to use the clamping feature of your typical cover. So I looked at it for a couple days, decided to toss the OEM attachment hardware.
    I attached some 4 foot sections of aluminum 90* along the bed top rails. I then noticed in order to get the locking mechanism to work the width of the cover need to be adjusted.... wasn't sure it could be done... but I figured somebody made it... so I should be able to take it apart, worst case I destroyed it.... Turns out these things are sheet metal panels with a Styrofoam with aluminum rails down the side to complete the panel. Once I figured that all out - It was just a matter of measuring it out....
    Took the cover down to its components and took .035 off each side and put it all back together....I still have one more bracket set to make for the first panel that attaches to the tailgate. I wouldn't call it a tight water proof install - but I think it will get the job done.
    no turning back now:
    After I cut everything down it went together like a typical cover.
    Now I just need to touchup the black paint.
  11. Likes Geoff H liked this post
  12. #88
    Nice flush fit. I like it. I need to do something like that on my truck.
    XTF #2
    GTM # 344
  13. #89
    Prescott, AZ
    That is one hell of a street truck. I am really impressed how stock the truck looks to those that don't know what a Factory Five is. Great job and looks like another happy Hellion customer.
    So what is next?
  14. #90
    Huntsville, Al
    I think I am building another 65 coupe while I decide.....
  15. #91
    Huntsville, Al
    This should close out this thread - thanks for all the interest - finished 2023 pretty strong - will start another thread once we get towing!
  16. #92
    San Diego
    Well I have a question and this seems like the most appropriate thread so...
    Do you happen to have any links to articles or videos from SEMA 2023 where the FFR Truck is featured...or even mentioned?
    I have been looking at a bunch of SEMA 2023 videos and have not seen anything about the FFR truck? Seems odd to me. You know like "Best Accessory Kit" videos and it is about some hood scoops/vents, or a "ground effects" kit? Seems like the FFR kit is far and above any of this kind of stuff and should have stolen the show as far as "upgrade" items are concerned. I know, I know to get many of those awards and accolades it takes the mordida, but I find it hard to believe that there wouldn't even be a mention?
    Show us where you (anyone) have seen the FFR XTF in videos or pictures at SEMA 2023.
    www.myraceshop.com
    GTM solution kits
  17. #93
    Huntsville, Al
    Yeah not sure - we did a bunch of interviews - not sure what's up with the coverage honestly - I did about 30 minutes with Cars.tv and haven't seen that yet - they said some time in Jan.... not sure.
  18. #94
    Huntsville, Al
    Got some Towing/Trailer testing done - long video - but show the overall impression first hand and the setup from going from a street rocket to a tow vehicle in about 30 minutes
  19. #95
    Huntsville, Al
    Another milestone... you can actually tow a Factory Five WITH a Factory Five.. even got caught in the rain.... still a few adjustments to be done but happy with the performance overall...
  20. Likes edwardb, Geoff H liked this post
