Would anybody know if a clutch quadrant from a 1979-93 mustang would work for roadster? Thanks
yes if your using a mustang pedal box.
mike
no, i'm using the wilwood. i've been waiting for the quadrant/cable for a while now from f5. read the cable isn't very good so i was thinking of buying a kit from late model restoration which includes cable,quadrant,adjuster and fork which i need too.
you'll need the clutch quadrant assembly from FFR if you're using the wilwood box. I think i just saw someone recently selling the quadrant assembly on this forum or possible on FB.
get a Ford OEM cable from Mike Forte. Much nicer than the kit provided one.
Free one here if you still need it
https://thefactoryfiveforum.com/show...of-Build-Parts
MK2 Roadster - 347 - Boss 302 Crate 4x2 Weber 44 IDFs
Completely incompatible parts. Keep in mind the Wilwood pedal box is intended (designed) for a master cylinder driving a hydraulic clutch setup. Factory Five designed some pieces that convert the clutch pedal location to pull the clutch cable. There are drawings and illustrations in the build manual. The parts aren't available elsewhere. And yes the cable Factory Five supplies is inferior to a genuine Ford cable. An easy solution is to go hydraulic.
