Rear bulkhead mod brainstorm
I am trying to make my MKIV somewhat reasonably period correct. With FFR it's much easier to make 289 period correct, but I decided to go down the 427 path with an S/C layout, so here we are.
One thing that's "wrong" is that the real bulkhead closes. 427 competition had exposed rollbars with an FIA bump:
Comp cars had the battery at the back:
Street cars had it closed with a vinyl and had storage, similar to this:
Naturally, the latter is easier to do with the FFR design, but I do have a driver side rollbar (with a crossbar for seat belt). On the passenger side, I plan to do this, regardless of which option I go with:
So now that leaves me with two options.
Option 1:
Go with the faux comp look. Move the rear bulkhead back. But with FFR, the step is deeper and higher. So I plan to put a faux battery there with a fire extinguisher on the other side, that wont add any depth:
(pardon my photoshop skills).
It should look like this without losing any space for the passenger:
Option 2
The second option is easier. Just vinyl the back and put a leather / vinyl pocket there, similar to the CSX3283 I showed above:
But it's sort of incorrect because the rest of my car follows the competition look, but it'll be sort of incorrect either way.
So, internet, what say you?
Complete novice who doesn't know what he's doing.
MKIV with BPE 347 & TKX. IRS. A crap ton of mods.
Build thread
Not a waxer
If you move the rear wall back you won’t see both roll bar legs, only the inner one. The outer one joins with the chassis in the rear wheel well.
zee thanked for this post
Originally Posted by
Jeff Kleiner
More engineering :-).
Build thread
FWIW. Had a Morgan+4SS with the batteries 2X6Volt in the cockpit behind the seats & was never real comfortable with that part of it. Especially with the batteries of the time which you has to water as part of regular maintenance.
BEAR-AvHistory
It's a dumb place for the battery IMO. IF I do the exposed rollbar then I'll just have a fake 3D printed facade with stickers, the real battery will be elsewhere.
Build thread
