FF33rod
The firewall and footbox fronts install long before the floor pieces in both the Gen 1 and Gen 2 build manuals so they would end up under....
Mastertech5
Ditto. I had about 1/4" space between the floor and the footbox pieces. I jacked them up using a 2x4 and drilled the rivet holes. Then I gooped them with the marine adhesive, jacked them back up and 3/16 riveted them. 4 on each side.
Dang, I better read that manual a little better. Mine came with the floor panel under the lip of the firewall so I assumed that was correct.
Just 1 More
Yeah, just think of the joint, one is much harder to get water through. But since you'll caulk anyway, not a huge thing.
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
