Forward trans tunnel panel, Removable? or no.....
So I keep going back and forth with this. Did you make this panel removable? Or rivet it in place?
I'm planning on that panel being upholstered (either by itself, or a cover)
I've seen it both ways (removeable and not), but I'd love to hear some other peoples thought process on this?
I made mine removable so that I could get to electrical connections if needed. Easier to pull the panel to repair than trying to reach up around the tranny from underneath. Used nutserts. I also cut that panel so that I could pull the lower piece without having to pull the dash to pull the full panel.
I have a bunch of components, wiring, and an added switch panel on mine. So it's removeable too. Just in case. Like Scott's (Namrups). I also modified it (actually made a new one...) so that it can be loosened/removed without taking off the rear transmission cover. Which I also made removeable. The stock setup has the rear transmission cover holding down the front cover. I reversed that. If you're leaving it plain, you could rivet it place. But no downside, IMO, to having the front one or both removable.
Before covering everything up:
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Thanks for the input guys - I've always really intended to DO it that way, but the rivnut install is a ***** with that frame member at an angle behind it..... I have been considering making a panel with longer "sides" to it in order to make that better. Kind of nerve racking too since my rear brake line is run in that area, and I'd REALLY like to not hit it..... lol
RR
I would like to have mine removeable but am a bit worried about heat intrusion into the cockpit especially given the difficulty securing this piece. As mentioned above I did take steps to "de-couple" this panel from the center trans tunnel top. I simply attached an angled piece of aluminum that I can fasten to. So even If I rivet this piece removal will not be dependent on further disassembly.
I like both Paul and Scott's options presented above. I am also considering maybe a piano hinge at the top (limited benefit, but some access) and also building a slot that the top bit could slide into as this would help secure the top portion.
I'll post something once I'm settled on a direction!
Here is what I ended up doing for the forward trans tunnel cover. I ended up making a new one with longer sides (as suggested above) and added a piano hinge to the top front bit. Just need to clean up the edges a bit.
While it may not afford me a lot of room at least I have some access to that area if ever needed.
Forward Hinged Trans Tunnel Cover 2.jpgForward Hinged Trans Tunnel Cover.jpg
Originally Posted by
edwardb
Just want to say damn - that's a nice clean install!
