Originally Posted by
crash
Here is a picture before the current redo. It is really pretty straight forward. It just requires a bit of finagling around, particularly on the front, to get through the frame work and hooked up to the radiator.
It looks like you have it routed through the wheel well. I'll have to put a wheel on the car to check the clearance.
Did you have any issues when putting the body on the car?
ohmygosuness
Nope. There is lots of room. I did put aluminum shields over the tubes where debris would hit them from the spinning front wheels as a precaution.
Post Thanks / Like - 1 Thanks, 1 Likes
crash
This is good info. I was also wondering about the debris. Thanks.
