Results 1 to 7 of 7
Thread: Fuel pump specs and requirements for my 427EFI
    Sep 2021
    Hello everyone. Build 10314
    I am definitely lacking when it comes to fuel pumps and requirements. Is there anyone out there that can give me some information as to what is the required fuel pump for my 427EFI that is coming. Still not sure if it is going to be an inline or in tank fuel pump. Information as to someone who has already installed a good quality fuel pump into a 427EFI already would be greatly appreciated. Thank you so much
    Honest Ernie
    Nov 2021
    Texas!
    Size of pump depends on hp.
    (Modern) 427s usually run in the 550hp ballpark, give or take.
    What are the expected numbers on the one you have coming?
    That'll help with the sizing.
    Rob Windsor
    Sep 2021
    Quote Originally Posted by Windsor View Post
    Hello Rob. Stage 2 427 is expected to be in the range of 581HP. Hope this helps out.
    Honest Ernie
    PaulProe's Avatar
    Manchester, MO
    Ernie
    I am running an Inected FE - 468" w/ Borla Eight Stack system. I used the Aeromotive Phantom 340, it's an in-tank system. I ran a Phantom 200 in my previous big block (432" - Injected EightStack) and it performed well. Went with the 340 as the price difference isn't that great.
    Link to the Aeromotive system https://aeromotiveinc.com/product/ph...h-fuel-system/
    Paul
    Feb 2019
    Northern Virginia
    I have a stage 1 427 from BPE, I went with the largest Breeze pump kit. Mark also has the fuel return kit and everything else you'll need.
    Mk4 Complete Kit, Blueprint 427w EFI Stage 1, IRS, 15", Gordon Levi Wilwood brakes, FFR Power steering (Build Thread)
    Notes and additions to the official build manual (PM me if you would like access to contribute)
    Inventory tracking spreadsheet
    Senior Member Geoff H's Avatar
    Edmonton, Alberta
    I stumbled across this when I was researching:
    https://help.summitracing.com/app/an...p-do-i-need%3F
    Mk III 4880: 3:55 - 3 link, T-5, 347, Holley Sniper/dual sync distributor, Comp Cams XE274HR, Edelbrock RPM Heads
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Quote Originally Posted by mladen View Post
    This is also what I did, works wonderful.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
