Results 1 to 6 of 6
Thread: Gap in Cockpit Aluminum
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Aug 2021
    Cheshire, CT
    Hi all,
    Put the body on for initial fitment and rough work and noticed a gap between the frame and aluminum at the door striker - see pics.
    Should the bend in the aluminum panel be less so that it touches or is closer to the frame? Or is there something else going on here?
    Thanks in advance - Rich
    That’s how they are. Some builders make an aluminum (I use ABS plastic on the ones I do) splash panel which gets installed on the wheel well side to close up that big void.
    O'Fallon, MO
    You cut the bulb seal a little too short
    Mrk III, 331 stroker, Borla stack injection, T5, 3:55 IRS, Power steering and brakes. Kleiner body & paint
    Dublin, OH
    I made some cardboard templates and transferred to some aluminum to block that space from the wheel well side. I’ve read that you can expect a rooster tail of water soaking your side when driving in the rain otherwise
    So. Bay (So. Calif.)
    As mentioned, a simple panel on the wheel well side seals up that big gap nicely.
    Aug 2021
    Cheshire, CT
    Thanks, all.
