0
0
Coyote Oil Filter relocation...
Any reason this wont work:
http://www.summitracing.com/parts/TRD-1127/
It works with 22mm x 1.5 threads, which is what everything I can find and have been told the Coyote uses. $55 with lines and housings is a lot better than $170 just for the adaptor from Ford:
http://www.jegs.com/i/Ford-Racing/39...ductId=1430980
Am I missing something that needs special attention for the Coyote block?
Also, the OEM gasket is 2.800" OD and 2.422" ID. The filter kit works for 2-5/8" gaskets.
Skip all that and use a napa 7060 oil filter.
Originally Posted by
FFinisher
Geez, can you give me an easier/cheaper solution? I spent about 30 minutes at Advance going through filters and nothing was shorter than 4". Looks like I was at the wrong store. Thank you, sir.
