Results 1 to 5 of 5
Thread: Passenger Side Brake and Turn Signal Not working
    Senior Member clays123's Avatar
    Need help with lights..
    My brake light and turn signal on the passenger side is not working, they worked in the past but thin something went wrong when the painter reassembled the car, I had to fix a few things.
    All the other lights including the hazzards (all 4), parking lights works, licence plate, all work as they should.
    Any help is appreciated, thanks.
    Clayton
    Senior Member Scott L's Avatar
    Peoples Republic of Massachusetts
    I would check the ground.
    FFR 5385 MKIII. 302, 3-Link. All legal in MA 1/7/2012.
    Quote Originally Posted by Scott L View Post
    Ditto Regarding The Grounds!
    I actually have a pigtail to the frame for each light.
    Papa (Dave) and Jeff Kleiner advised me the over-kill for my extra grounds wouldn't hurt.
    Quote Originally Posted by clays123 View Post
    Clayton
    Now front works but back wont work for turn signal and brake light. Not a grounding problem as they work for hazzard and parking light.
    Jul 2020
    Spencer, MA
    Brake light and turn are the same circuit back to the turn signal switch in the column. Check that the 2 column connector halves are fully engaged together.
