0
0
25th Anniversary #9772
how accurate is the Aeromotive Fuel Pressure Regulator pressure gauge?
looking at a recent data log, I noticed the PSI at the ECU measurement is about 57 PSI (not enough) - although the aeromotive gauge is showing 65-67PSI
which should I believe? what has everyone's experience been with the Gen3 Coyote?
edit:
in the Ford instructions - mentions 65PSI, but 55psi at the fuel rail, engine off (assuming this is the ECU pressure reading?)
so it seems I may still be short on PSI according to the ECU
- You may not post replies
- You may not edit your posts
Forum Rules
