Coyote PCM/ECU placement? Urgent help needed!
I can't figure out where to place/mount the Coyote PCM/ECU and I'm seeking advice from those who have built a '33 hot rod or '35 truck with the Coyote engine.
Here's my two key issues....
1. the engine wire harness that connects to the PCM is located on the front right of the engine right head and is too short to get to the cab
2. the engine bay with the '33 Hot Rod and the '35 truck are the same and is too small to mount the PCM there that I can see.
My question is to those that have built a 33 or 35 and installed the Coyote.... where did you mount the PCM, and if it's the cab inside the firewall, how did you lengthen the wire harness on the engine to reach/connect to the PCM?
thx, Mark
My build link is in my signature below
Pic of PCM/ECU with the vehicle side wire harness.
- You may not post replies
- You may not edit your posts
Forum Rules
