Thanks Thanks:  2
Likes Likes:  2
Results 1 to 11 of 11
Thread: GTM Gen2 Carwash watertight?
    May 2016
    Trying to complete my car, i bought it 80% done wink wink, and...
    Am I naive in trying to make the car, excluding the door windows for now, carwash watertight?
    I am finding lots of places with potential water/air leaks.
    Upper rollbar though the rear window bulkhead.
    Lower outer seatbelt mounts.
    Being just a couple of examples.
    Just asking
    Sep 2015
    Hamersville, Ohio
    Lol!
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
    Senior Member beeman's Avatar
    Indiana
    I think the more reasonable goal is to not get soaked if you get caught in a light rain.
    GTM #304 LPE 525hp LS3
    Feb 2019
    Houston, TX
    I was unable to find an incomplete GTM at a reasonable price, so I settled for an 818. Based on my experience with that factory five car.... The only hope you have of making it water tight is to completely disassemble it and build it from the ground up with that intention from the start, and be prepared for tons of customization. It is in no way from the factory capable of such a task.
    Sep 2015
    Hamersville, Ohio
    Agreed!
    2017 Tundra
    May 2016
    Now I, and my car, feel normal!
    Aug 2012
    Grand Rapids, MI
    Can I watch? I have popcorn...
    Jim
    Member kabacj's Avatar
    Long Island
    Quote Originally Posted by doug_porsche View Post
    Just asking
    Well considering your car is already built, it’s definitely harder, but HVAC foil tape is your friend. It’s super sticky and will make openings air and water tight.
    I race in the rain with the windows open, but keeping stuff reasonably dry inside is important to prevent fogging. Tapping up the seams and openings will help.
    Harder to do on an already built car but it’s possible.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
  9. Thanks rolfer thanked for this post
    Likes rolfer liked this post
  10. #9
    wallace18's Avatar
    Trenton, Florida
    Having built over 17 FFR kits including a GTM you have little to no chance of ever making one of these kit cars car wash water tight. Plus IMO you should never run one of these in a car wash. Just my 2- cents. Hope you make me eat my words but I would not bet on it, LOL. Best of luck and enjoy your GTM.
    16+ FFR kits and counting!
  11. #10
    San Diego
    Use light and a good "gutter seal" product. In a darkish garage use a drop light from outside the car to look for light coming through from the inside. This is easiest done with two people. One on the outside moving the light and the other on the inside marking areas where light comes through. Once all the areas are marked, decide if the HVAC tape or the gutter sealant is more appropriate(I use both) to seal the area.
    We race in the rain at better than 150 MPH and have gotten it pretty well sealed. Remarkably the open windows do not have much water coming in them while at speed.
    I do not believe any GTM will ever be car wash sealed.
    Here's what I use.
    https://www.bestmaterials.com/detail...tent=Adhesives
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  12. Thanks rolfer thanked for this post
  13. #11
    Just asking
    When we build a car from scratch, that is always the goal. It's not that tough to do when building.....where there is a seam or gap that leads to the outside, seal it up with caulk or foil tape or weatherstrip. Yes, the door windows will always be the exception, but the rest of it really should be done anyway.....for 2 reasons.
    1. If you drive on wet roads, do you want the carpet and interior to get wet and moldy? If you don't seal everything up, it will.
    2. Anywhere that water can get in, so can heat and exhaust fumes (as in you example of the area around the seat belt mounts and halo tubes). If you don't seal those areas up 100%, you will get a ton of heat coming in from the engine bay. FFR provides close-out panels to seal those areas off.....but of course, they require a bit of extra work to actually seal them....again....application of tape, caulk or weatherstrip where necessary.
    Shane Vacek
    www.vraptorspeedworks.com
