I was just like you with my 331 with high compression heads. I used Car Chemistry 2 disk inserts in the end of the side pipes. They sell them at Summitt. The are pressed in (or hit in with a rubber mallet) and then held in with a single stainless steel rivet. I did not weld the optional end cap on. It helped a lot. At normal driving, the drone is gone and I can now have conversations in the car without yelling. I had bought steel wool packing to put between the inserts disk but wanted to hear it first without it. I wish I had placed the steel wool in now as now it will not be as easy to do it. I am very happy with the results. IMG_0398.jpg
