So I've searched both this forum and read over the manual a couple of times and I think I know the answer to this, but I wanted to get feedback.
The manual states on page 37 of "Suspension Build Up": The suspension has two sets of holes. The top set is for a lower ride height (4-4.5”) while the
bottom set is for a higher ride height (5.5”).
Shortly afterward it states: If running the lower suspension hole set-up, the front lower control arm left side rear tab will have to be
cut to the upper bolt hole location as shown so that the steering rack will not hit it.
They literally mean the "bottom hole" when they say "lower suspension hole set-up" and aren't talking about the lower ride height correct? I think the intermingling of the word lower for ride height and hole is messing with me.
Another way to ask would be if I want the lower ride height, I use the upper holes and I don't have to cut anything?
