Chrisg00
I have a Gen 2 kit. Think I know what you mean with regards to the carriage bolts. After reading up on a lot of threads, I too tightened the bag out of them once the gaps were set. But this last time when I took the door off, I could lift the hinge arm and see the slop where the pin is going through the bushings. Tried tightening the pins but they are bottoming out. I will try to take a video and upload it on here for you guys to see.
Yah, I know what you mean about the slop from the bushing. I've seen it on some of the owner's builds. Can you compensate for the slop by setting the door higher and then with the bushing slop it will settle to the location you want it?
Just a thought?
Jim
