Has anyone used a set of old wheels and tires during the build and go-kart stages? Seems like a good way to avoid installing expensive tires just so they can start to age-out. I found a set of 18" mustang wheels/tires for $200.
Terry
Terry, did the same exact thing! Didn’t want new tires aging while the build was going on.
Rob
Mk4 Complete Kit, #10465
Ordered 11/14/21, Build School 5/20/22, Delivered 8/22/22, Engine/Transmission Delivered 3/27/23, Installed 9/3/23, First Start 2/14/24
347FI/TKX/IRS "Street Look"-no hoodscoop or rollbar, undercar exhaust
Every car that goes through the build process here at the i.e.427 Garage get our shop wheels with inexpensive street tire. Tires are good enough to go-cart the car if necessary and if the wheels get scratched during the build process it saves the customer's pretty wheels. We run the pressures up on our shop tires (about 40 PSI). It make the cars easier to maneuver.
Thanks Frank and Rob.
Terry
Space saver spares are a dime a dozen.
I've seen guys on other forums use plywood for temporary tires/wheels, though with the cost of lumber nowadays not sure how much money that would save. I like Steno's idea of tracking down some cheap space-saver spare tires from a junk yard.
Ok John, now I think I've seen everything.
Terry
I looked into getting some of the steel blanks that summit and others have but they're expensive........
These will do. They were cheap, tires are decent, and 18" so no clearance issues.
BUT... the 50-series tires make them kind of wagon wheel-ish. .
Terry
I think it boils down to being honest with yourself...how long is this build gonna take.
Terry
At the 8 minute mark I'm like... I hope they throw fuel on it and light em on fire. If you're gonna be a bear, be a grizzly right?
Literally at 9:43...
