Sorry to have brought another frustration with my suggestion!
I ran out to check, maybe there is something specific to these cars we all deleted that causes issues, but mine reads and logs fine. 07 WRX donor. Don't connect the green thing for logging, just in case you're doing that. It's only for flashing.
I have an older laptop from 2010 or so, at one point it got updated from Windows 7 to 10 and I remember it being a big pain to get Romraider to read from my 03 WRX at the time. Pretty sure I had to do a full "clean" java uninstall, restart, and install the correct one, then change some settings to make sure it wouldn't auto update. Also, I don't think it will do anything until you get the separate definitions files installed.
You get logger definitions here: https://www.romraider.com/forum/view...p=66788#p66788
You get ECU definitions here: https://www.romraider.com/forum/topic360.html
