Results 1 to 2 of 2
Thread: alignment of steering rack on mk4
    Oct 2020
    In assembling the power steering rack on the mk4, I notice that the steering arms are slightly angled forward when connected to the spindles. Is this correct or should they be straight across? If not correct, how should I make the fix?
    Quote Originally Posted by Edo Pellizzari View Post
    Yes, that is correct. Semi related; the bolt on steering arms should angle outward and the wide end of the taper should be down to accept the tie rods from the bottom.
  3. Thanks cc2Arider thanked for this post
