Fan and shock clearance, what are you guys doing?
I don't have enough clearance between the shock mount and the fan. If you jack the car up, the bolts hit the fan. You can see the radiator is all the way out on the brackets. How are y'all addressing this issue?
Loosen the bracket to grill bolts and tilt the grill more upright. I had the opposite problem. The replica parts shroud hit the LCA mounts and I had to tilt it back more.
Originally Posted by
Mastertech5
If I tilt it upright, the bottom of the fan shroud hits the LCA mounts
Looks like you have spacers between the radiator mounting tabs and the mounting tabs on the grill shell. I am assuming the two lines coming out between the two are for an AC condenser.
I don't have AC and the fan is no where near touching anything with no spacers. Anyway you can adjust the condenser so you don't need the spacers?
Dgc333
No, That's the way it has to be for the A/C condenser.
The nut should be on the side facing the fan. I cut the nut almost in 1/2 so it wouldn’t touch the fan when it’s jacked up.
1/4" made all the difference, This is jacked up wheels off the ground
When it's on the ground it's not an issue.
Mastertech5
The 1/4" gives me the peace of mind for when I'm doing my stunt jumps
Post Thanks / Like - 0 Thanks, 3 Likes
My car is 007 so I might have been the first to address this.
Yes, the bolt heads should be on the "engine" side so you can extract them w/o any fuss in the future.
Best wishes,
Tom
