Well, for those who didn’t see the thread in the regular Roadster forum, the brake issue got worked out: I sent the 11.65 back for a refund and bought some EBay new take-offs from a Mustang.
Got the brakes bolted up, with zero issues. So, I’m happy about that.
Once I got the brakes on, I proceeded to work up my E-Stopp install, which turned out pretty good. I just used a piece of 1/8” 6061 plate, and mounted to the front side of the fuel tank hangers. I ordered the 2015 Mustang e-brake cables from Rock Auto, but had to resize them both. I tapped the hole on top of the knuckles so I could bolt down my home-made cable clamps—I tried drilling out a couple 3/8” cable clamps and those failed miserably. So I replaced them with plumbers strap, works perfect.
I have a cable block on order from Summit. Once that comes in, I’ll be able to tension the cables and hook the system up to my power supply and test.
Since my in-laws came over for Christmas Eve, I spent some time in the garage mocking up the base mount for the ABS. It’s very solid with just Clecos holding it together, and should work out just fine. I tried to leave enough room for the Breeze battery box. From pics I’ve seen from others, I should be good with this setup.
