Results 1 to 3 of 3
Thread: needing help
    needing help
    Gents,
    I have a 93 Grand Marquis rear end to my 33 Hot rod kit that have the same spec of the 86-93 mustang GT rear end. ( 8.8", disk brakes, 59.25" hub to hub )
    I cut all the supports and I need to weld in the marquis the 2 supports that hold the news that are included in the kit, but I need to know the distance between the 2 supports, center to center too do that.
    I appreciate if somebody give to me the distance that I need.
    in a att. there are a drawing.
    Tks a lot
    Jose
    Tech Support, FFR Brian Z's Avatar
    Wareham MA
    Jose,
    We do not have the exact spec for the control arm mounts. You will need to set them up to bolt into a fox body mustang. (1979-1993)
    Best regards,
    Brian Zakrzewski
    FFR Tech & Sales
    Senior Member Gopher's Avatar
    McHenry, Illinois
    Send me a email address and I can measure the jig I made to do what your doing. I should be able to make you a drawing of what your looking for.
    Anniversary Special,Dart Aluminum 427, AFR 225 outlaw heads,Howard Cams,Hillborn stack injection,Liberty Gears prepedTKO600, Five Link, ISIS Wiring,8.98 @151 with no power adders Photo album HTTP://photobucket.com/anniversary-car
