Results 1 to 3 of 3
Thread: Found
    Banned
    PA, USA
    Found
    Found
    Prescott, AZ
    Which filter adapter are you after, the short nipple that permits removing the OEM oil cooling assembly or the oil cooling assembly. I have both from a 2nd Gen Coyote.
    Banned
    PA, USA
    I need the casting that bolts to the block. If it has the nipple that allows direct filter attachment, great. If not, that's ok too.
