Found
Found
Which filter adapter are you after, the short nipple that permits removing the OEM oil cooling assembly or the oil cooling assembly. I have both from a 2nd Gen Coyote.
I need the casting that bolts to the block. If it has the nipple that allows direct filter attachment, great. If not, that's ok too.
