Results 1 to 9 of 9
Thread: Exhaust body opening
    Member PMad's Avatar
    Massachusetts
    OK the car is going to paint a week from Friday and the last project before it goes is figuring out to get the headers to clear the body. They hit the bottom of the opening on both sides and I can't get the gap between the nose and the pontoons right until I can figure out how to get clearance. There isn't much fiberglass there and I'm afraid to just start grinding. Help!
    Pat Madigan
    Junior Member Brian Palmer's Avatar
    Chicago Area
    I ended up timming it down there a great deal. And what little is left cracked some time in the first two years.
    It's going to have to fit and I don't think the headers bend well. You might shape some aluminum to the shape of the fiberglass left at the bottom when you're done and neatly rivet it in.
    Brian
    Massachusetts
    Thanks Brian. I think I might have to reinforce the top of the pod too, it looks like I'll have to remove enough to make it pretty thin. Good excuse to also buy Russ' pod covers too.
    Pat Madigan
    Member KodiakCoupe's Avatar
    Kodiak, Alaska
    You could try shimming the engine mounts a bit. I had to do this to gain needed clearance on my psgr side.
    steve
    The Coupe Du Jour #443
    http://www.flickr.com/photos/38188992@N04/
    Massachusetts
    Hmmm, probably should have thought of that one. How much did you have to shim it? Did you use anything special?
    Pat Madigan
    Kodiak, Alaska
    In my case, I only needed the psgr side up an inch or so. To get that amount on the moment end of the headers, I used less than 1/4" at the engine mount. I used two large door style shims. At some point, I will probobaly go back and fab a full size shim in stainless that matches the footprint of the mount. For now, i'm happy with it. Your results at the header ends will probably vary since both sides need to go up in your case.
    steve
    Fort Lauderdale Fl.
    If theyre both hitting evenly your going to have to trim, not that big a deal. Take a deep breath and jump in..............HTH Steven
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Massachusetts
    Thanks guys, it's this weekend's project. I'll let you know how it goes.
    Pat Madigan
    Oct 2014
    Las Vegas nv
    I had the same problem and I resolved it by taking the side pipes to muffler shop and had bends put in header pipe to give more clearance then had them ceramic coated
