Possible to adjust toe on a rack & pinion without disconnecting the rod-ends?
Hey Y'all,
I've never adjusted toe on a rack & pinion equipped vehicle before. There doesn't appear to be any exposed "turn buckle" mechanism. Does the rod rotate inside the rack & pinion unit?
I noticed that the steering rods that come out of the unit have "flats" on them -- I'm guessing for toe adjustments.
It seems kinda counter-productive to have to remove the rod ends in order to adjust toe, yet I've read on other forums that you don't want to rotate the rods more than a turn.
What's the proper way?
Craig C
Just loosen the nut next to the tie rod. The shaft turns freely in the rack. That is how toe is adjusted when doing an alignment.
16+ FFR kits and counting!
Generally I've just loosened lock nut, loosened the clamp for the dust boot / bellows (and made sure they broke free of the inner tie rod). Then turned the inner tie rod as needed to adjust the alignment using the flats provided. Never heard of being limiting on turns, normally the inner tie rod uses a ball joint of sorts where it connects to the rack and can spin as it pleases. Google a picture of a mustang inner tie rod and you'll get the idea.
Thanks guys!
That's what I'll do then and not worry about having to remove the rod ends
Craig C
You guys have flats on yours? I was looking for them on mine but no! I'll have to put my own on I guess.
Curmudgeon
Mastertech5
If you have enough thread exposed: Take it apart and install a second nut (or two thin nuts). You can then use them backed off and tightened together to rotate the shaft, avoiding the dreaded vice grip tooth marks. After adjusting it becomes a second jam nut.
