Thread: Gen III Coupe IRS driveshaft loop...
    Hey Folks,
    I need to add a driveshaft loop to Gen III Coupe #17.
    I'm not interested in welding or bolting to the frame cross-rails as many have done.
    I did buy the Metco driveshaft loop but it does not fit:
    https://metcomotorsports.com/mdl2500
    I came across the attached photo (from a YouTube car sales video.
    Anyone know what this drive shaft loop is?
    Mar 2021
    Ohio
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    That is an interesting find. Haven't put my driveshaft loop in yet and there isn't much space for the one I have
    Mar 2021
    Ohio
    Quote Originally Posted by rhk118 View Post
    Which one do you have? I have not bought mine yet.
    Lilburn, GA
    Dave,
    Hard to tell, but this pic looks like the loop is around the U joint at the rear end. The loop needs to be at the U joint nearest the transmission. If the front U joint fails, the driveshaft would beat the trans tunnel, and through the thin aluminum (if you didn't have the loop). That's the reason for the loop. If the rear U joint fails, the driveshaft would rattle around and fall out.
    coupe driveshaft.jpg[/QUOTE]
    Nov 2021
    Portland, Maine
    Quote Originally Posted by burchfieldb View Post
    I bought the basic Summit one: SUM-G7900 - https://www.summitracing.com/parts/SUM-G7900 . Mine isn't installed yet and is similar to the one Paul used. Arms will need to be cut down and the hoop might need to be cut down, although I think the hoop will fit. The space to mount the arms to the frame is very tight though. Paul managed to get 3 bolts/nutserts per side and I just don't see that I have the space back there to get 3 in per side. Also to Ducky2009's comment above I might cut the hoop part down to make it smaller so in the event of a failure the driveshaft has less room to roam if that makes sense. I will be looking at the hoop in the next couple weeks though and if I can't find a satisfactory way to mount it then might have a buddy help me weld it on...
    I do like the one Dave found because it eliminates bolting or welding to the frame (if it fits, no reason not to believe that one would). Dave - if you get it let us know...I'm still months away from having an engine/transmission combo to install. I do think the Summit hoop could be installed on your car though without having to mess with the transmission/driveshaft. Do you need it for track regulation? I've been impressed by how hard you use your car and getting it out there in events.
