Results 1 to 11 of 11
Thread: sidepipe mounting bracket
    Jul 2022
    DFW Texas
    looking at the manual it says to bolt the sidepipe brackets through the 2x2 square tube and use lock nuts on the end of the bolt in the foot boxes. do people hit their heels on the bolt ends? do you carpet over these? is there an acceptable alternative like rivnuts in the 2z2 instead of a through bolt?
    thanks
    JJ
    Mk 4 complete kit w/IRS delivered (mostly) 10-31-22. BPE 347FI w/TXK.
    Aug 2012
    Grand Rapids, MI
    No sure but I think the bolts run parallel to the ground and floor. This puts them through the 2x2 tube from front to rear not up & down.
    But then I'm just guessing.
    Jim
    Jul 2022
    DFW Texas
    Jim, you are correct, but I believe the nut and end of the bolt protrude into the footbox through the 2x2 tube.
    Oct 2020
    Albany, NY
    You drill the hole then slide the bolt through pointing back toward the seat pan. The nut and rubber grommet are under the car. The only part in the footbox is the head. I carpeted over it and never thought about it again.
    Build Thread https://thefactoryfiveforum.com/show...been-delivered
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I copied Edwardb and used 5/16 nutserts rather than drilling all the way through the 2" tubes. You can read about it in his build thread here. Turned out extremely solid and nice not to have the bolt heads in the footwell.
  6. Thanks danmas thanked for this post
    Likes danmas liked this post
    Jul 2022
    DFW Texas
    JohnK, I thought I had read that somewhere but couldn't find it. I think this may be my approach as well. Thank you
    JJ
    Aug 2012
    Grand Rapids, MI
    Sorry JJK. I was guessing. Now I realize the bolt goes through the front 2x2. I thought it was further back.
    Jim
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Thanks for this. I like this a lot. Commenting so I can also find it again when I get there…
    Mk4 complete kit arrived 10 May 23
    Current BOM
  10. #9
    So. Bay (So. Calif.)
    I also used nut-certs in the 2x2 tube. Here's some pics, and text, on what I did in another thread. Post #3. https://thefactoryfiveforum.com/show...l=1#post535329
  11. #10
    Senior Member SJDave's Avatar
    Santa Clara, CA
    Railroad's design is really nice for adjustability; my approach is adjustable but with washers in the vertical direction. I put two Rivnuts into the bottom surface of the 2 x 2 tube and used a piece of 2x2 angle iron with a slot machined into mount the FFR hardware. The slot gives you in/out, washers under the angle iron give you up and down.
    Mk 3.1 #6616 Complete Kit, July 2008 Start, Gromm Racing 347, TKO 500, IRS, Carmine Red / Wimbleton White
    Mk 3.1 #6756 Complete Kit, May 2016 kit completion, Smeding Alum. 427 Stack Injection, TKO600, Custom Silver/Blue (SOLD)
  12. #11
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    Lot of interesting approaches listed here. I kept it simple and drilled through both sides of the 2x2. Unless you put your head in the foot box, you can't see the bolt head. Because the bolt head is smooth, there is really no risk of injury. If you decide to use floor mats they cover everything up and it is a non-issue.
