Thread: Randy’s Gen 3, New to Me
    Oct 2023
    Austin
    Picked up a 2007 FFR Mk3 that was last worked on around 2010. Towing it home on an open trailer got rid of most of the dust None of the aluminum panels have been attached, which is great since I will be able to clean up the frame. Many of the parts are still in the original boxes. It came with a DART SBF SHP 351W/427 still wrapped in wax paper with heads, etc. loosely bolted on. The list of parts is pretty good based on what I have read.
    Dart SHP 351w/427 Short Block
    Pro Products 6.4" Harmonic Balancer
    Comp Cams Extreme Energy 235/240 Hydraulic Roller Cam
    RHS 35002 Aluminum Cylinder Heads, 64cc Combustion Chambers, 200CCIntake Ports, 2.02"/1.60 Stainless Valves
    Procomp 1.6 Ratio, 7/16 Stub Mount Rocker Arms (P/N 2332)
    Elelbrock RPM Air Gap Endurashine Intake Manifold
    Holley 77CFM Street Avenger Carburetor
    FE Style Coolant Expansion Tank
    FFR Radiator & Cooling Fan
    K&N Air Filter and Xtreme Filter Top
    MSD Pro Billet Distributer
    Tremec TKO600 Transmission
    Pro 5.0 Midshifter
    Quick Time 6063 SFI Bellhousing
    Ram 98794T Clutch/Pressure Plate
    Ram 1529 Billet Steel Flywheel
    Forte's External Hydraulic Clutch Kit
    Wilwood Pedals
    American Racing Thick Flange Stainless Steel Headers
    Gas-N Polished Stainless Steel Side Pipes
    SN95 Brakes
    Ford Thunderbird Super Coupe Rear Axle Housing
    Fresh Trac-Loc Diff (3.55 gears)
    TA Performance Diff Cover Girdle W/Stud Mount
    Flaming River Steering Rack
    Halibrand Style 9"X17"/10"X17" Wheels
    Vredestein Sessanta Ultrac 255/40ZR-17 and 315/35ZR-17
    SAI Mod
    Tubular Rear Control Arms W/Spherical Rod Ends
    Adjustable Front Upper Control Arms
    Leather Seats, Dash Cover & Door Panels
    Russ Thompson Turn Signal Kit
    Vintage Air A/C Kit W/Defroster
    Autometer Gauges
    Dual Black Powder Coated Roll Bars
    Super Snake Hood and Liner (still has the Standard FFR Hood as well)
    Lowered Rear Body Mounts
    Rectangular Tail Lights
    Battery Relocation Kit
    Member KippRacing's Avatar
    May 2023
    Central Iowa
    Nice! Happy building and welcome to the forum!
    Milton,DE
    Check the date codes on the tires.
    Grand Rapids, MI
    Quote Originally Posted by Olli View Post
    Yes on this.
    The Vredesteins are good tires, but I don't think they've been manufactured in 6 or more years.
    They'll be ok for basic rolling stock and driving around the neighborhood but not much past that.
    Sounds like a great car.
    Jim
    2016 Mk4 Challenge Car, IRS, 3.31 Torsen, RDI Aluminum 427w, AFR 225s, Vic Jr. ProSystems 780 HP, TKO-600 w/Liberty mods. Forward cage. Levy 6/4 piston Wilwoods. Not completed yet, will be a streetable track car.
    2004 Superformance MkIII #1855, 2007 Superformance MkIII #2584 purchased in 2012 both sold.
    Oct 2023
    Austin
    I need help identifying the aluminum panels. I figured out most of them, but there are a few that I apparently don’t have and others I just can’t figure out. Hoping there are pictures somewhere I can reference. Thx in advance.
