Thanks Thanks:  3
Likes Likes:  2
Thread: Headlight Body Rivets
    I had to remove my headlights the other day to get paint protective film installed, and when I went to reinstall them I noticed they had a little rotation even when fully tightened to the chassis. After inspecting I saw that the rivets that hold the mounting flange to the headlight body were all loose. I have a Gen 2 with the relatively heavy LED lights mounted through the side panels. I only have 200 miles on the car so they worked loose pretty quick. I initially just crimped them down tight again, but was worried they would just loosen up like before.
    So I knocked the rivets out and replaced them with M5x10 screws and nylon lock nuts. The rivets were pretty thin wall and very easy to remove, so I'm sure they would have loosened up again. The lights are reinstalled and plenty tight now with no more extra rotation.
    Thought I would post as a heads up in case anyone might run into this too.
  2. Thanks Jeff33Ford, Just 1 More, Mastertech5 thanked for this post
    Likes RoadRacer, Just 1 More liked this post
    Yep, I noticed one of mine had loose rivets recently. Mine lasted longer than yours, but this is a good fix for it.
    At least yours lasted longer. Maybe I got second source rivets installed on Monday morning or something.
    Senior Member Nigel Allen's Avatar
    South Australia
    Great solution.
    The stainless screw heads respond really well to buffing if needed to match the chrome headlamps.
    Gen1 Coyote / TKO600 / IRS
    Thanks Nigel.. If I get really ambitious I'll try that.
    May 2018
    Chaska, Minnesota
    Thanks for the heads up. Much easier to do now than after they are bolted tight to the car. I am going to upgrade mine.
