Thread: Ford 5.0/302 Parts
    Jun 2023
    Texas Hill Country
    Ford 5.0/302 Parts
    Forum Friends, these parts are from a Ford 5.0 Small Block with 81K miles in a 2000 Explorer. I used the roller block for my 347 build which is now ready for install. I did not find anything unusual with these parts during disassembly. I split my time between the Texas Hill Country and DFW area so can meet in most of Texas. Or I can ship at buyer’s expense.
    1) GT40P Cylinder Heads with rocker arms, pushrods and head bolts. $250
    2) Complete EFI System with lower manifold, upper plenum, injection rack with injectors, throttle body, camshaft position sensor w/ oil pump drive. $150
    3) Crankshaft $75
    4) Pistons/Rods $75
    I have pictures I can send via PM.
    BUDFIVE
    Kingsland, TX
    I'm building a mild 302 based off a '97 Explorer 5.0 similar to yours. Fortunately I have the GT40 (non-P) heads, so I'll be using the long block.
    I would be interested if your Cam Sensor is 2-wire or 3-wire. Also, would you consider selling the front cover (timing cover) and harmonic balancer?
    Also, I have a complete front accessory drive for the Explorer if you know anyone interested.
    GLWTS!
    Jun 2023
    Texas Hill Country
    Mike, I’ll check the cam sensor in the morning while I'm at my shop in Kempner at the ranch. FYI I live in Blue Lake/Horseshoe Bay 10-15 miles over from Kingsland. BUDFIVE
    Jun 2023
    Texas Hill Country
    Mike sorry for late response—my roadster was delivered today-check my build thread. Anyway, the cam sensor is a 2 wire. Here’s a pic with the part #, too. BUDFIVECamsens .jpg
