Out of necessity
I'm redesigning the hinge to swing from a different point so that I can lift the nose without hitting the splitter.
I wish FFR would have done that for the R versions.
when you're racing and something bad happens sometimes you can't get the hood open FAST enough
I'm fortunate to have access to anything i need to build it how I want to
my slitter is 2" from ground at track ride height.
my SFI 25.1 spec frame has 1" more ground clearance than the FFR frame.
my wheel well lips are less than 25.5" from ground in front and 26" in rear
