Quote Originally Posted by J R Jones View Post
Bob, The drag is experienced with either L or R rear wheel, and when one wheel turns, the other wheel does not. My assumption is the differential is open.
Jim, When both wheel are up in the air and you have an open diff. The ring gear could be totally frozen , then turning one wheel should just rotate the other wheel in the opposite direction. Bob
edit: Maybe you have a wheel bearing issue.
