Likes Likes:  2
Thread: Helpful Hint for Installing Control Arms
    Dec 2022
    Hey fellow coupe builders. I wanted to provide a helpful hint for installing control arm rod ends into narrow mounting brackets. While trying to install my rear suspension, I found it difficult to jam the rod ends into the chassis brackets. Several of them were about 1/16th of an inch too narrow. So I tried to find a tool that would make the openings a little wider. I finally found this handy gadget at Advance Auto parts. It's a brake pad spreader that is operated with a 3/4 inch wrench, and made the job easy. I hope this helps anyone who is struggling with this same situation.
  2. Likes MSumners, 65 Cobra Dude liked this post
    Jan 2019
    Richland, WA
    That's a great find/idea. There are probably a few more places that would also come in handy. Wish I would have thought of it for my build— if I remember properly, I think my tool of choice was a couple big-*** crescent wrenches.
    --jim
    Build 1: Gen III Type 65 Coupe, Gen II Coyote
    Senior Member cv2065's Avatar
    Dec 2017
    Nice find! Haven't seen that one before. You can also use some simple threaded rod with two nuts and 2 washers. Easy to get in some of the small places, as you'll need to spread the ears out in just about every installation, from UCAs, LCAs and shocks.
    Dec 2023
    I just used that technique last night. Have used it several times before in this build. Cheaper than buying a tool
