Jim1855
I'm planning a front "blade" along the 4" front crossmember and then tubes welded to the main 4" frame rails. The pan ends up at about the same height off the road as it was for the first 60k miles of this motor. For me, maybe not for you, I'm more concerned with height above the road than I am drop below the frame.
So I cheat and modify the frame.
Jim
How much ground clearance you thinking you will have?
Roadster delivered 8/27/23
Chevrolet Performance LS3
