Likes Likes:  6
Results 1 to 12 of 12
Thread: locating/planning a defroster vent without the body
    Folsom, CA
    I'm on the fence about putting in a defroster vent, I have heat & A/C and there's room on the driver side for a vent, but probably not the passenger side without creating a whole new vent and space is at a super premium...
    is there a guideline on how much 'hose' should be used to locate the vent? I know in general you want the hose as taught as possible to reduce airflow disturbances
    has anyone done just a driver side defroster? I know it's a roadster, but my buddy the other night used his defroster because the dewpoint got low enough to fog up his inner windshield and it helped tremendously
    also, if a soft (or hard) top goes on in the future, it would probably be beneficial as well
    Todd
    Almost every one I've done has a functional defrost vent on the driver's side only and a non-functional grill on the passenger side. The heater box &/or glove box usually makes it virtually impossible to get a hose on a boot on the passenger side.
    Jun 2023
    Texas Hill Country
    Jeff, is the heater box in the way for a functional passenger side defrost vent with the FFR heater installed per the instructions? If so, what do you do with the top passenger side box output? I’m about to pull the trigger on the FFR heater/defrost kit this week as other kits don’t have the box outputs on the side which is all we have room for, right?
    Toadster, glad you started the thread.
    BUDFIVE
    Complete kit order 8/28/2023
    347 Ford Dyno 10/12/2023
    Kit Delivery 11/28/2023
  4. Likes toadster liked this post
    Senior Member Norm B's Avatar
    North Racecars sells a plenum to solve this issue https://northracecars.com/heat_ac.html. Scroll down the page on the link.
    I made my own adapter to allow defrost on the passenger side.
    HTH
    Norm
    Mk4 base kit 7721, 331 Stroker, Holley Sniper EFI, Wipers, Heater, Whitby Soft Top, Drop trunk mod and more
  6. Likes toadster liked this post
  7. #5
    Cape Coral, FL
    Quote Originally Posted by BUDFIVE View Post
    I installed the heater but did not put in the defrost vents. I cut off two outputs and then formed a block off plate out of AL and riveted into place with sealer to the openings.
  8. Likes toadster liked this post
  9. #6
    Edmond, OK
    I've got the North Racecars plenum ... works well and makes the defrost vent openings much less mentally contentious.
  10. Likes toadster liked this post
  11. #7
    Folsom, CA
    will check with the painter/body guy (KenP) about the North Racecars plenum - looks like that may work!!!
    Thanks guys!!
    Todd
  12. #8
    Dublin, OH
    I capped off my unused port with a large rubber end cap.
    can't remember the exact OD of the port but something similar to this.
    https://www.amazon.com/Prescott-Plas...89&sr=8-3&th=1
  13. Likes toadster liked this post
  14. #9
    I think a lot depends on exactly how and where the heater box is mounted as well as what defroster boot you're using. The ones that point straight down are generally a no-go. I had a North Racecars plenum supplied by one owner and due to conflict I had to cut it up, reshape it and and then 'glass it all back together before fiberglassing it to the underside of the cowl. I use rubber Fernco test plugs to cap the unused heater box ports. You'll find them in the plumbing section of your local hardware store, Lowes, etc.
  15. Likes toadster liked this post
  16. #10
    Jan 2022
    Seven Hills, OH
    I was able to install both on both sides as functional, but I have a custom heater box setup. Videos in my build thread below if interested.
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  17. #11
    Folsom, CA
    Quote Originally Posted by Jrmotorsports55 View Post
    wow love the innovation in your setup, I'm subscribed to your youtube as well
    Todd
  18. #12
    Jan 2022
    Seven Hills, OH
    Much appreciated! Thanks!
