I’m looking at some double lock sliders with a common bar but don’t want the seat to eat my hand when I pull forward. I know several of you have used several brands and wonder if anyone can tell me if theirs has the adjuster travel with the seat?
MkIV Complete - Dart 427/TKX/Sniper II/IRS from Forte
As far as I know they all do. Otherwise, once it was forward you couldn't reach the handle. I did have one car come through my shop that had them mounted upside down. did exactly what you describe.
For my '33 Hot Rod, I used these from Summit. I had to modify the cross wire that attaches the tract brackets but that was pretty simple. https://www.summitracing.com/parts/SUM-G1153
I'm pretty sure if you just flip over the slider (upside down), the handle will travel with seat. Typically, the handle is attached to the bottom of the slider, but if you flip it, it'll be attached to the seat.
Ted
Sweet thanks for the quick responses!
I have a pair of the Sparco, double lock sliders. Summit has these for about $80/set although prices have probably changed.
The slides are independent, and the adjustment bar can be changed to accommodate various widths. These are quite low at about .6" thick.
Jim
2016 Mk4 Challenge Car, IRS, 3.31 Torsen, RDI Aluminum 427w, AFR 225s, Vic Jr. ProSystems 780 HP, TKO-600 w/Liberty mods. Forward cage. Levy 6/4 piston Wilwoods. Not completed yet, will be a streetable track car.
2004 Superformance MkIII #1855, 2007 Superformance MkIII #2584 purchased in 2012 both sold.
keep in mind if you want to track the car, you'll want dual locking rails, I used this allstar setup (or very similar) from speedline
Allstar ALL98100 Seat Mounting Track Assembly Kit with Adjustment Handle, Universal ~$50
https://cobradreams.com/2023/04/04/m...t-heater-pads/
How much do these kits raise the seat? I am 6 ft tall and am concerned with the top of the windshield frame obstructing my view
