Results 1 to 2 of 2
Thread: 4 way hazards wiring
    Senior Member Junbug's Avatar
    Apr 2022
    Lafayette, CO
    Quick question. FFR instructions for how to hook up the 4-way hazards leave a bit to be desired. I searched this site and believe this is the correct way to hook up the RF wiring harness leads to the FFR provided switch. I believe I’ve used the correct switch… Please correct me if I’m wrong! Thanks!
    -Bryan
    Mk4 Roadster w/ IRS, Forte Gen 3 Coyote/TKX, Wilwood Brakes
    Build thread https://thefactoryfiveforum.com/show...oyote-TKX-EFI)
    Ordered: 6/27/22, Delivered: 1/20/23, First Start 10/16/2023, Go-Cart 3/30/2024
    Jun 2015
    Fairfax Station VA
    You've got it correct.
    MK IV Roadster #8631
