Likes Likes:  2
Thread: Grill angle, how do you know?
    Sep 2022
    Huntington, IN
    How do you know when you've got the proper grill angle? I've got mine set to where the fan and shroud clear everything. Nothing touches. It seems like the right spot to me. How do you know?
    Oct 2022
    There is no specific angle the grill is supposed to be set to. I set mine so it minimized the amount of triming I had to do to the hood.
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    If I remember correctly the manual said 53 degrees? Check the manual it should be in there. I used an angle finder tool.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
    Especially if you're not running bodywork, do whatever looks good to you! I even laid back my '32 grill
  5. Likes Just 1 More liked this post
    Oct 2022
    Quote Originally Posted by CaptB View Post
    There is nothing in the Rev L manual about what angle the grill should be at. It states to leave the screws loose so you can adjust it when mounting the hood. In the hood section it says to use a straight edge from the grill to cowl and adjust the grill so there is no gap at the cowl.
    Sep 2022
    Huntington, IN
    The original owner/builder had already started trimming the hood and lower panels. With the grill where it's at right now, the hood only needs some finish sanding to fit. The lower panels are way off.
    Placitas, NM
    Most of us had cut and rebuild that lower panel to make it fit the contour of the lower part of the grill.
  9. Thanks Just 1 More thanked for this post
