Having finished the battery box framework, I needed to make a battery box to secure the battery to the framework. That was today's activities. DSC02837.JPGDSC02838.JPGDSC02839.JPGDSC02840.JPGDSC02841.JPG
Todays activities was to fabricate and install a new .125 thick 2024 T3 Aircraft aluminum firewall. I used a 2"x2" 1/8" steel angle overlaped on the 2" square beam by 3/8". A one inch weld every 4 inches top and bottom. Then installed three 90' supports underneath for added support. I drilled two 1.250 holes to route the two wire harnesses striaght down, rather than coming out of the firewall. DSC02843.JPGDSC02844.JPGDSC02845.JPGDSC02846.JPG
