9
I decided (and the wife agrees) that there should be an "oh crap" handle below the glove box. I had ordered the CF Dash so I mocked it up to see if there was room for steel reinforcement. There is! So now we have a steel plate weled to the 2"x 2" crossmember to attach the grab bar to. Its just got 1/4" pilot holes now. I'll fab up a nice handle that will match the rest of the cockpit down the road. DSC02856.JPGDSC02857.JPGDSC02858.JPG
I did not want my braided brake lines attached to the chassis with a couple aluminum pop rivets, so I made a couple more clips for the rear brakes so I could weld them on.DSC02859.JPGDSC02860.JPG I lowered them from the FFR position as I plan to route a 3" duct hose to cool the footboxes through that space. There will be two duct inlets in the cubbie leading to a pair of 3" bilge blowers ducted down to a 1"x4" duct running alongside the seats to vent the footboxes. Pics will follow when I do the sheetmetal.
Today was a good day. After reading some good advice from some of the above posts, I decided to go with a power steering sytem. I have a 351W stroker. I have the CVF Pulley system and the Saginaw pump would interfere with the steering shaft. So I wont be using the CVF power steering. I did not want to use the late model pump converted to vee belt. SOLUTION= Epowersteering.com. Lance showed me his Electronic Power Steering System and I am sold. I aquired the Epowersteering kit for the MK4. I spent today mocking up the steering rack and shaft so I could intigrate the new electric power assist unit. The instructions were pretty easy to follow. I did add an additional support running from the 4" tube to the supplied attach bracket system. I did not want a 15lb motor assembly bouncing up and down being supported by a thin walled 3/4 tube. Then I mounted the brain box within easy reach of the existing electrical pigtail. Then I broke it all down and put it all away leaving only the weled on support brackets.
Been busy getting my 47 Merc Coupe into the Portland Roadster Show. It is up on display so
I have a free day to finish the welding. I see the late model solid axle calls for a cross over line to the right rear brakes. I decided not to route it back by the fuel tank. I crossed it over behind the 2x3 frame. This reqired 4 clips to be welded in.DSC02867.JPGDSC02868.JPG
