Likes Likes:  13
Results 1 to 38 of 38
Thread: GTM #30 Build thread
    Jan 2024
    Figured I might as well start up a build thread for ole #30. I am the third owner now of this unfinished car. The previous two owners had the car in running go kart stage. But I plan to redo a lot of the car and upgrade a bunch as well.
    The car currently has donor 97 Vette parts on it. LS1, with a G50/01 trans.
    Here is a list of my proposed build and upgrades. Not all may be done, just depends on what the budget allows.
    - Caddy XLR Northstar M122 supercharger, with Fabworks head adapters and billet fuel rails.
    - Ractronix C5 fuel pump setup, lines, filter, and regulator. Injector Dynamics ID1050x LS2 injectors.
    - HP Tuners new CORE ECU setup. IF this winds up being in the budget, I will be using the traction control option with it.
    - Wilwood Aero6 calipers, front and rear. C6 Z51 front rotors, C6 Z06 rear rotors.
    - Variant Alloy custom made wheels. 19x8.5 +44 fronts, 19x11 +38 rears. 245-35/19s and 315-30/19s.
    - Brandwood shifter setup with Shane's brackets.
    - Aircups spring lift setup.
    - Touchscreen Center console control system.
    - Relocate coolant tubes to outside the frame under the body.
    That's the plan so far. More things will be added as I learn more about what other people have done on their cars. I do have to admit, it's a little disheartening seeing the lack of activity on the GTM forums, but I do understand I'm coming into this almost 20 years since the introduction of the car. Maybe my posts will bring some people back out of the woodwork.
    Also, if ANYONE out there has a lead on a set of GTM door window glass, please contact me!
    Senior Member beeman's Avatar
    Indiana
    Great first post, looks like a nice list of changes and upgrades.
    I'm 8 weeks out from shoulder surgery, can't do anything for another 4 weeks. I'll admit that other projects have distracted me from the GTM as well.
    I have all of the GTM glass except for the windshield in NE Indiana, where are you located?
    GTM #304 LPE 525hp LS3
    Jan 2024
    Hey Dave, I'm in Florida. You have door glass available?
    Indiana
    Quote Originally Posted by Power Surge View Post
    I am 99% sure I have all the glass except for the windshield. It is all in the original packaging, I would need to confirm nothing has been broken while it has been in storage.
    I purchased the kit 2nd hand like you did
    Jan 2024
    Awesome. Please check on that when you can and let me know!
  6. Likes beeman liked this post
    San Diego
    Is the door glass not a donor part from a Vette? Seems like those should be available from a wrecking yard? It is all the other windows that are specific to the kit...windshield, rear window, and quarter panel glass, right?
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Indiana
    I think the door glass is quite a bit smaller than Corvette
    San Diego
    I never had any door glass in my GTM so maybe I am confused. I thought that was one of the parts used from the donor. I thought that was why the door windows did not seal very well. Again, maybe I am mistaken since I never had to work with those. The only glass my GTM has is the windshield. I have changed everything else to non kit speced items.
    www.myraceshop.com
    GTM solution kits
  10. #9
    Jul 2014
    Door glass is a kit item.
    Power Surge - where in FL are you? I'm in Palm City on the east coast.
  11. #10
    Jan 2024
    Quote Originally Posted by Shoeless View Post
    Palm Coast/St Aug here.
  12. #11
    Jan 2024
    Unfortunately it's an FFR made item. And they do not have any. I did just get a new windshield from them though. But I'm missing the door windows.
  13. #12
    Feb 2019
    Houston, TX
    This probably a blessing in disguise. You can now find some windows that are reasonably close in size (or make some from plexiglass) and rework the entire tracks and sealing mechanism and have a much nicer car.
  14. #13
    Jan 2024
    Is this a thing? Do you have any details?
  15. #14
    Feb 2019
    Houston, TX
    The 818 guys have retrofitted S10 truck window guides, I'm betting a day in a salvage yard would find something close to the right size for a GTM:
    https://thefactoryfiveforum.com/show...l=1#post447240
  16. #15
    Sep 2015
    Hamersville, Ohio
    Yea, just make a template of your required glass curvature and use that template to compare with windows to at the salvage yard. Make sure it’s large enough to accommodate your profile then take it to a competent glass man and have him cut it down to size. Don’t forget the guide channels, you’ll need those too.
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
  17. #16
    The door windows are complicated enough with glass that FFR designed specifically to fit. Personally, I doubt you're going to find anything usable from a production car. Those windows can't be cut down to size because they are tempered glass.
    Sounds like you have a pretty solid build plan. Good luck!!
    Shane Vacek
    www.vraptorspeedworks.com
  18. #17
    Sep 2015
    Hamersville, Ohio
    I thought a diamond wheel would cut it. My bad. Fwiw, all of the FFR door glass is a pain to get right.
    2017 Tundra
  19. Likes VRaptor SpeedWorks, LLC liked this post
  20. #18
    Feb 2019
    Houston, TX
    I was recommended mostly production guides, with glass as an unlikely bonus. Look at 1965 mustang window hardware, it’s relatively simple and might could be trimmed down to fit. Since you have no glass you might be stuck with plexi
  21. #19
    Jan 2024
    Well I'm hoping beeman will hook me up with his unused glass
  22. #20
    Indiana
    Crap, forgot to look at it, I'll try to find it in the next couple of days
  23. Likes Power Surge liked this post
  24. #21
    Indiana
    I do have the side glass still in the factory wrap. I don't know how well it would travel. PM me if you want it.
  25. #22
    Aug 2021
    Kansas City
    What coils and and shocks are you planning on using? I might have the air cups you need for half price.
  26. #23
    Jan 2024
    Quote Originally Posted by frankenford View Post
    I'm using the yellow Konis that came with the kit. But I already have them on order from stance parts
  27. #24
    Aug 2021
    Kansas City
    Awe that's too bad because that's the ones that I have. If you decide you want some for the back let me know.
  28. #25
    Jan 2024
    I wanted to do the rears...but it didn't look like there was room? Shoot me a pm.
  29. #26
    Indiana
    Side windows ready for shipping, my daughter helped
  30. #27
    Feb 2019
    Houston, TX
    Those nails look like the perfect color blue for your car
  31. Likes beeman liked this post
  32. #28
    Indiana
    You might be onto something there! I'm getting Gulf Blue vibes. How many bottles of nail polish are recommended for an average sized coupe?
  33. #29
    Or.....stay with me here.........buy a whole truckload of fake nails...paint them all individually and the glue them to the car like dragon scales?
    Shane Vacek
  34. Likes beeman, Shoeless liked this post
  35. #30
    Feb 2019
    Houston, TX
    This is brilliant, your body work gets cut by 100x. No blocking or guide coat needed.
  36. Likes VRaptor SpeedWorks, LLC liked this post
  37. #31
    Jan 2024
    Parts are starting to roll in
  38. Likes VRaptor SpeedWorks, LLC, beeman liked this post
  39. #32
    Member kabacj's Avatar
    You are going to love it. The GTM is not easy to build, but it’s so much fun . Lots of people here to help you evaluate solutions to any problem you have.
    Im looking forward to your progress.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
  40. Likes Power Surge liked this post
  41. #33
    Jan 2024
    Ok... this weekend was the first big milestone after buying the car. I was able to get the body off, and then roll it outside to powerwash a decade or so of dust/dirt/etc off the entire car. Also got all the new wheels installed
    Now I can really get a good look at the car, and formulate a game plan going forward with what I want to redo and change/add to the car from this point.
  42. Likes VRaptor SpeedWorks, LLC liked this post
  43. #34
    Jan 2024
    Some more goodies for the build came in....
    Stanceparts Aircups (fronts only)
    Fuel Injector Clinic 775cc injectors
    Racetronix 255lph in tank pump, with upgraded wiring harness
    Also got a bunch of small panels and brackets from Shane!
  44. Likes VRaptor SpeedWorks, LLC liked this post
  45. #35
    Nice! The air cups sure come in handy a lot!
    Shane Vacek
  46. #36
    Jul 2014
    Any reason you didn't go with the tankless air cup set? It actually works really well without the tank.
  47. #37
    Jan 2024
    Because I didn't know any better? lol
    Not much info out there with people having them on GTMs. I'm not opposed to running it tankless.
    Sal Mennella
    Unfinished GTM #30 FFR - in progress!
    Roadster 5132 - sold
  48. #38
    Jul 2014
    No worries, we all learned as we progressed through our builds.
    If you have the option, I'd swap your kit for the tankless setup. One thing the GTM does not have, as you are likely seeing, is spare room to mount extra things.
  49. Likes VRaptor SpeedWorks, LLC liked this post
