Thanks Thanks:  2
Likes Likes:  3
Results 1 to 20 of 20
Thread: Sniper seem to run rich
    Mar 2021
    Bradenton, FL
    Blueprint 347 with Holly sniper. have done many.... proably too many....starts and just idle to show off the sound. I am now at the go-kart stage and when i put it in gear it wants to stall, il drive a hundred yards give a little punch and engine will stall. A lot of exhaust smell.... I am thinking it is running too rich. Also now does not start imidiately as it did in the beginning. I just installed NEW identical plugs and verified the gap.
    Whats everyones thoughts? before i call Holly.
    Feb 2021
    What gen is the sniper? I had almost exact same problem, my sniper was very old generation. Unable to fix, neither was Holley. Just got new sniper. Problem solved.
    Mar 2021
    Bradenton, FL
    Quote Originally Posted by Blessidsoul12 View Post
    Well, that is unfortuante. So you had to buy one or Holly replaced it?
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    I just got a new Sniper II on my 347. One thing we had to tune correctly was the return to idle settings. At first it would die every time I came to a stop. We had to fiddle with the RPM above idle to catch it and the timing settings of settling down back to the desired idle speed. It's taken a bit to get it right and I'm now about 400 miles in on my new motor and 99% of the time it returns to idle perfectly now. About 1% of the time it will almost die, but catches itself, so I think I'm very close. It also does seem a tad rich, and soon as the weather warms up and I can drive it more. I've also made a dyno appointment with people far better at this then I am!
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
    Where is your O2 sensor? My Sniper (replaced with Inglese MPFI) was very sensitive to fresh air near the sensor. Running without the full exhaust caused lots of problems. Also, the fuel enrichment settings will dump a ton of fuel into the engine until the coolant is above 160 degrees. Be sure your CTS is on the engine side of the thermostat. It's also very important to go through the setup wizard with accurate selections and verifying all the sensor values. Have you verified the fuel pressure? The built-in regulators on the Snipers are known to fail.
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Chris:
    Do you have the little Holley handheld unit connected? Suggest you go to it and pull up the indicated exhaust O2 level while the engine is idling.
    If it’s reading super rich (10 or 11 to 1) then all the advice given above will help you.
    If it is reading lean at idle (say sound 13.5 or higher, or no indication ) it could be via multiple short starts and stops you’ve inadvertently fouled up the O2 sensor. I did that on a previous turbo LS powered Foxbody Mustang build with a Holley HP system and had to purchase a new sensor.
    Everything returned to normal after replacement.
    Just a thought…
    Pat
    Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
    Mar 2021
    Bradenton, FL
    Thank you gentlemen, I will proceed as adviced here, over the next few days. I will post my findings.
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Check the pressure, mine was at 90psi with 2 regulators fighting it out. A call to Holley and I pulled out the internal regulator in the Sniper. BAM! 60 psi.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
    Mar 2021
    Bradenton, FL
    So.... I confirmed and saved all the correct setting on the handheld, 8 cyl, mild cam, coil. Then while cranking today nothing but a1 short fire tyhen nothing. AFR while cranking showed 34.5 in red.
    I will call Holley in the morning....
    Quote Originally Posted by Chris Wingardh View Post
    That is likely a bad O2 sensor.
    Senior Member weendoggy's Avatar
    Aptos, CA
    IF, you do have a failed O2 and you've been trying to run the engine a lot, you've already corrupted your base tune, so, you'll need to investigate that part when you start over. One way to check if the O2 is bad is, if (keyword) you have a good base tune and you don't drive/run the engine much when first encountering the issue, put the tune in OPEN loop and the engine should run well enough to get you sorted out until you replace it. So many things can cause your symptoms and this is just a slice of what it could be.
    Also, during cranking the O2 will not read actual due to the fact it hasn't warmed up yet, so seeing anything above "normal" isn't uncommon.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Mar 2021
    Bradenton, FL
    Thanks, I will do that. Heve a new O2 from Holley comming... just in case.
    Jun 2018
    North Vancouver, BC, Canada
    FYI, you don't need to go to Holley for the sensor. A few mfgs make them including Bosch. What you're looking for is 4.9 Lambda wide band sensor, 5 wire.. like this:
    https://www.amazon.ca/dp/B0863P6YLQ?...roduct_details
    Gen 1 '33 Hot Rod #1104
    Mar 2021
    Bradenton, FL
    WOW! 100 buck's cheaper and will be here tomorrow. Thank you sir.
    Dec 2018
    SW Calgary, AB
    Hi Chris!
    So did a new O2 get your truck running correctly?
    Also, did you go with the lower cost option suggested by FF33rod?
    If so am thinking to pick one up from there as a spare for my current project.
    Thanks!
    Pat
  16. Likes john42 liked this post
  17. #16
    Mar 2021
    Bradenton, FL
    Sorry for the late reply. It has been quite embarising........ I was out of gas!! Everything is fine. Sometimes stupidity just cant be overcome!
  18. Thanks Pat Landymore, Geoff H thanked for this post
    Likes FF33rod, Pat Landymore liked this post
  19. #17
    Dec 2018
    SW Calgary, AB
    Don’t ever be embarrassed Chris!
    There are so many factors involved when a fellow is building a hot rod…some are familiar and some brand new…that at times the little things can get caught up in the 100 different other things a guy is thinking about and get lost in the fray.
    Really pleased for you that your fix was simple and low $$.
    Don’t ever ask me to offer a list of my ‘forced learnings’. It would be very long…..Ha 🤣
    Best Regards!
  20. #18
    Mar 2021
    Bradenton, FL
    Thanks Pat, I know so so many things. Happy it was cheap. Cheers
  21. #19
    Apr 2020
    Chris,
    I figured I would chime in here as well. I have a Sniper Stealth TBI system with Terminator X and it runs super rich. So rich to the point that after about 7 or 8 starts and 25 miles on the odometer it carbon fouled all my spark plugs and the engine would not event start. After changing the spark plugs it fired right up. I will say that some of the carbon fouling came from me not running the engine for a long time at operating temp. I would basically just get the engine up to temp, do some idle tuning on the handheld and then shut it off. Keep an eye on your spark plugs if you start having issues again. For my tuning, I started at reducing the fuel Prime shot and after start enrichment. There are a lot of forums on the internet that discuss this. Hope this helps.
    V/r
    Shakey
    Shakey. Coupe Base kit ordered Dec 2021. Build thread: https://thefactoryfiveforum.com/show...-Daytona-Build
  22. #20
    Mar 2021
    Bradenton, FL
    Quote Originally Posted by Shakey View Post
    Chris,
    V/r
    Shakey
    Thank you Sir, I will dig in to it in a little while.
