Thanks Thanks:  5
Likes Likes:  8
Results 1 to 14 of 14
Thread: Need Stainless or Aluminum Upper Radiator Tube.
    Senior Member Rebostar's Avatar
    Jan 2024
    Hello All.
    Can anyone tell me or better yet post a link where I can get an upper radiator metal tube. I've seen several on You Tube but unable to make contact. I talked with Boig and they told me it would "be a while till they did another batch of 1.5 tube". I plan to get the Breeze lower tube but cannot find the upper. Any help would be greatly appreciated.
    Allyn
    Jan 2024
    Opps....Sorry...351W stroker. FFR Radiator
    Allyn
    FFR MKIII builder/owner
    Nov 2012
    Danbury Ct.
    Not sure exactly what you need but I get email ads from Jegs and the other day one of the things listed was an assortment of tubing shapes for radiator connections. Might check that source if you haven’t already.
  4. Thanks Rebostar thanked for this post
    Likes Rebostar liked this post
    Port Charlotte, FL
  6. Likes bill1982 liked this post
  7. #5
    Jan 2022
    I had Boig(Tubular Automotive) bend me a tube out of exhaust tubing and they have a referral who a the ability to coat it inside and out.
  8. #6
    Senior Member Mike.Bray's Avatar
    Dec 2021
    Flower Mound TX
    You can make your own easily from aluminum tubing. Fill it with fine sand and cap the ends for kink-free bending. Then add the beads with one of these. https://www.holley.com/brands/earls/...tools/beaders/
    Done it many times.
    My build thread https://thefactoryfiveforum.com/show...Roadster-Build
    Thread on Stainless Steel AN brake lines.
    Thread on fasteners and torque wrenches.
  9. Thanks Rebostar thanked for this post
  10. #7
    Jan 2022
    Mike,
    Where are you buying the aluminum tubing in @6' lengths?
  11. #8
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by MC Builders View Post
    Mike,
    Try McMaster Carr, Metal Supermarkets, or Online Metals. Lately I've been using Metal Supermarkets.
  12. Thanks Rebostar thanked for this post
  13. #9
    Nov 2016
    "The i.e." SoCal
    You could just eliminate all the extra points of failure and use a Fox Mustang upper hose.
  14. #10
    Jan 2024
    Thanks ALL.
    I'll order the tube and the bead tool. I'll check the exhuast shops to see who has a 1.5" tube bender. I have 200 lbs of sand for my sand blaster so I'm good there! All the tubes I found on Summit and Jeggs were for turbo chargers and intakes. I'll refine my search. I called Boig first, sounded like he wanted out of the 1.5 cooling tube business, or maybe he just wont be doing 1.5" for a while.
    Thanks again
    Allyn
  15. #11
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Rebostar View Post
    Use relatively thin wall aluminum tubing and leave it long for leverage. A good vice or steel table, maybe a little heat, and you can bend it by hand. Done it many times.
    When you're finished I would anodize it to give it protection.
  16. #12
    Santa Clarita, CA.
    Here is a way to just keep it simple.
    I am not sure if the links are still good but here is a parts list.
    1 - 12" x 1.5" stainless tube
    http://www.allpurposepipes.com/1.5-i...ipe-p-829.html
    1 - 45 degree elbow 1.5"
    https://www.ebay.com/itm/1-5-4-PLY-4...dYZfqZ&vxp=mtr
    2 - 90 degree elbow 1.5
    https://www.ebay.com/itm/Verocious-9...taGZlC&vxp=mtr
    1 - Set T-Bolt clamps
    https://www.ebay.com/itm/6PC-For-1-1...pXoZz0&vxp=mtr
  17. Thanks Rebostar, MPTech thanked for this post
    Likes Rebostar, Railroad, Fman, bill1982 liked this post
  18. #13
    Bill_VA's Avatar
    Manassas, VA
    17+ ago, I found a guy who was going to market an aluminum upper tube and I worked with him to prototype it. I got the first and only one he made. It's pretty nice!
    Non-donor - Engine Factory 351w/400hp - TKO500 - 3-Link - Cobra brakes - FFmetal - Wilwood pedals - FR500 wheels - NCPainter
    Owner of FFmetal.com
  19. #14
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    Your idea is a really nice plan for a very low cost. You could also go with aluminum pipe for a different look.
    https://www.amazon.com/AUTOHAUX-Leng...38&sr=8-1&th=1
    Build #9818 completed 04/2021 - Dart SBF 427, PF4 EFI, TKO600 Build thread: https://thefactoryfiveforum.com/show...utton-head-mod
    Build review video:https://www.youtube.com/watch?v=k6IAbo2sFt4&t=1111s My finished car: https://thefactoryfiveforum.com/atta...7&d=1638415131
