Likes Likes:  2
Results 1 to 12 of 12
Thread: Aeromotive Canister Fuel Filter
    Jan 2023
    Bothell, WA
    Just finishing up my fuel lines and did a quick pressure test. Looks like the fuel filter is the culprit, no leaks/bubbles at any connection.
    I tried tightening the cannister and it is still leaking. Does anyone have any experience with this model?
    Aeromotive fuel filter, Part Number: 12317
    Aug 2012
    Grand Rapids, MI
    A new O-Ring possibly?
    I use a Canton fuel filter of similar type, it uses O-Rings, perhaps the AeroMotive does as well.
    Jim
    May 2023
    Frisco, TX
    I have the same filter and don’t have this issue. Have you inspected the o-ring and seat area for damage?
    As much as this unit costs, if swapping the prong doesn’t fix the problem, I’d return it and get a replacement.
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
    Jan 2023
    Bothell, WA
    ahhh frick. yes, i think its o-ring related. I remember opening the unit to check it out and read on aeromotive that the o-ring should be replaced if opened.
    Just ordered some new o-rings.
    Sep 2022
    Hmmm...I wonder if the TrickFlow has a similar issue...especially since I did the same thing (opened to have a look) ?
    https://www.trickflow.com/parts/tfs-23006
    Craig C
    Senior Member Its Bruce's Avatar
    Houston TX
    Maybe dumb questions, but is this an EFI application and is the filter good for EFI (higher pressure vs carb)?
    MK4, 427LS3, IRS, T56 Magnum, Wilwoods
    Nov 2016
    "The i.e." SoCal
    Make sure to lubricate the o-ring.
    May 2018
    Milwaukee, WI
    Quote Originally Posted by Its Bruce View Post
    Somebody here can correct me - but I think it is ideal for EFI - but you can use it for a carb. Well, I am using it on my carb application but it is probably overkill.
    BUILD THREAD: The Brew City Cobra
    Current Build: MK4 Complete Kit, Delivered December 2021; First Start November 9, 2022; Go-Cart November 23, 2022; Carbureted 427W, TKX, IRS
    Senior Member BRRT's Avatar
    Sep 2020
    It is rated to 200PSI, so normal EFI pressures should be no problem. Either porous aluminum, bad machining, or a bad o-ring. My bet is o-ring.
    Like Frank said, a little lube on the o-ring is necessary when assembling.
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
    Jan 2023
    Bothell, WA
    *update; Can confirm that it was the o-ring. Replaced it with Aeromotive 12008 and no leaks. Holds steady pressure.
  11. Likes BRRT, Mbufford liked this post
  12. #11
    May 2023
    Frisco, TX
    In addition to the 12008 o-rings, for anyone using this filter, the replacement element part number is 12608.
  13. #12
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    I had the exact same scenario, took it apart before I even installed on the car and leaked shortly after I had my first start. I called Aeromotive and they sent me a few o-ring gaskets and has been fine ever since (6k miles on car now). Aeromotive IMO makes some really nice components and has really good customer support.
    Glad you got it figured out.
