All,
Doing the final interior install (finally)…
Looking for some options/suggestion to clean up the door threshold area and the outside corner areas next to the door.
Any/all suggestions are appreciated.
Mark
All,
Mark
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
I make it out of a single piece. only thing left will be a small triangle are that will need to be filled at the bottom of the "v" FFR sells the carpet by the foot.
This stair edge worked pretty good.
I use the same as Chewy, you can get it in 3/4 or 1"
https://www.homedepot.com/p/Alexandr...6C01/205576693
MK4 #11012 picked up 04/16/24
351W, 3 link, single roll bar
MK4 #10616 picked up 4/10/23
MK4 #9759 picked up on 4/3/19
Thanks all. This was the direction is was thinking about going. I will look into some trim options.
Any other creative options/suggestions for the body to interior transition?
I used some textured 1/8" ABS plastic to clean up the locking post area. Easy to cut to fit and then bend around the corner with a heat gun.
are you talking about the under door part of the body? most use that C channel trim piece to hide the transition. Dark water customs made a polished aluminum trim piece, but I think Chris is no longer making products. I actually had my hands on a pair of these transition pieces but sold them as it required some shaping to fit correctly and I didn't want to mess with it on a freshly painted car.
I got black anodized aluminum from online metals dot com. Blends in with the carpet better
Yes, that is the area and the kind of option I am looking for (I recalled see the dark water option but couldn’t find it)
Any other options out there ??
