Good luck. The engine and some of the IRS will work. Trans is more trouble than is worth. Getting all the electronics to talk and behave is going to be a monumental task. You might be better off with the Mustang.
Wrong shifter location, non-standard driveshaft compared to the usual transmissions used, non-standard mounting, less than ideal gear ratios. All can be dealt with. But the effort and result needs to be compared to using one of the recommended ones. TKX the most common, T-56 less common, and an occasional T-5 which used to be the norm but not so much any more.
