Likes Likes:  2
Results 1 to 9 of 9
Thread: Turn Signal
    Jan 2018
    Turn Signal
    Purchased a used MK4 and it needs lots of work. Currently trying to get steering and wiring sorted out. This is the turn signal system that was in the car. I have no experience with these cars but I imagine you guys could help identify this? I'm looking for wiring instructions for it... however they had it set up, it was wrong.IMG_20240331_093707150_HDR.jpg
    Senior Member Jonathan D's Avatar
    Jun 2012
    New Brunswick, Canada
    No experience but I have seen that style on several websites like here https://www.speedwaymotors.com/Self-...ns,418733.html
    MK4 Build In Progress - Carb 331 Stroker, T5, 355, 15's, Pwr Brakes & Steering
    Build Page https://thefactoryfiveforum.com/show...Canadian-Build
    Jan 2018
    Thanks. This should help.
    Copperhill, TN
    That looks like an early VW switch, I got mine from Richard Oben, but they are getting hard to find.
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    That is definitely a VW turn signal. The same type that Russ Thompson used to produce (RIP). I'll look for the wiring instructions, but I know there is lots of different ways these guys do the wiring. Mine has five wires, the fifth is for the button on the end of the shaft that Russ added. If I'm correct, you'll have four wires (left, right, ground and flasher). Many use an IDIDIT relay; below is the IDIDIT relay schematic and my handwritten schematic of the wiring.
    RT:IDIDIT schematic.JPG IDIDITrelay2.JPG
    #10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
    • Order Date: September 11, 2021 - 20th Anniversary of 9/11
    • Delivery Day: April 1, 2022 - April Fool's Day
    • First Start and Go-Kart: January 20th, 2023
    • Graduation Date: July 4th, 2023 - Independence Day!!
    • Legal Registration Date: October 4, 2023 - My Birthday!!
    Visit my MKIV Build Thread (#10333)
  6. Likes JimStone liked this post
    Jan 2018
    Thanks Ted. I don't know much about the original builder, but from what I do know, I would guess that he used the Russ Thompson version. What I'd really like to do is replace the entire column with an ididit column. I've used these in the past on other projects and I like the quality and look of them. Any idea if there is one that will fit in these cars? I'm searching the forums, but not having much luck finding a solid answer.
  8. Likes Ted G liked this post
  9. #7
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Quote Originally Posted by eaglecook View Post
    I don't think there is enough room for the ididit column at all. I also think think they would stick out way too far into your lap.
  10. #8
    Jan 2018
    Yea, I was a little worried about that. I know they make them in different lengths, but any of them that I've seen look too big. I havent' had much time to work on this thing (very frustrating), but once I do, I'll get it all figured out. Was just hoping for a simple fix. :-)
  11. #9
    Mar 2014
    Crossville, TN & Punta Gorda, FL
    I used a Flaming River tilt column -- 32 inches long. This is on a MK I with a 460 motor.
